5,406
974
Obergebiet West
HJ Shoulder Staps, an introduction
Shoulder straps worn by the Hitler Youth served three basic purposes. They indicated the rank of the wearer, they identified the geographic location of the unit, they indicated the assignment designation of the wearer, and they indicated the branch of the Hitler Youth to which the wearer belonged. When viewed in combination with the Gebeitsdistrict triangle sleeve insignia, unit identification could instantaneously be made.
From time to time the shoulder straps underwent modification, new ranks were introduced and new Gebiets were raised. When looking at HJ shoulder straps it is neccessary to consider the year that the straps are from. Very early shoulder straps prior to 1933 were worn by youth elements that sometimes employed a dual colored piping that was most likely an indication of the Landesfarben, (National Colors used by each German state), that went around the sides and to the point of the boards. These early boards are difficult to find and considered to be rare.
Early Pattern HJ Shoulder Straps
The first standarization was achieved in 1933. The basic first pattern shoulder strap was made of light brown uniform cloth. Regulations prescribed that the width be 44mm inclusive of the 2mm wide piping that bordered the outer edge. Some straps were without this piping and only measured 40mm. The length was 125mm from the base to the pointed end. Included on the strap was the retaining button, the Bann number, the Unterbann number, and where appropriate the rank insignia and piping.
Early pattern 1933 shoulder straps had several distinct charateristics. The button measured 19mm in diameter. It was a pebbled button in either plain field grey, field grey with a raised arabic numeral depicting the Gefolgshcaft, (a company sized HJ unit), silver to corespond to with the tunic buttons of leaders, or gold to corespond to high ranking leaders tunic buttons. The number was later dropped and unumbered buttons were used. There was some variance to this as period photos show.
Regualtions of November 24, 1934 called for some changes. The Bann number was in arabic style. It measured 18mm high, and normally was a chain stitch type of sewing. The number was in the color of the respective HJ Obberbann. The respective Obberbann colors were as follows:
Obberbann 1-Red
Obberbann 2-Yellow
Obberbann 3-Green
Obberbann 4-Blue
Obberbann 5-Black
Obberbann 6-White
The Bann number was positioned above the Unterbann number on the strap, in the center.
The Unterbann number was positioned below the Obberbann number on the strap. It was also normally in a chain stitch type sewing. The number was a Roman numeral and ranged from I to V. It measured 10mm in height.
I, II, III, IV, V are the only Unterbann numbers that should be encountered, however known period documents show Unterbann number of up to VII, so regulations were not always adhered to.
Transitional Straps During the Abolishment of the Obberbann System
The Obberbann system underwent changes begining in 1934, and by the end of 1935 was abolished. The time period during 1936 saw changes to the straps. Specialisied straps that identified the wearers assignment were introduced during this time frame. During this time there was a period when the Obberbann straps and specialist straps co-existed, making determination of the wearers assignment sometimes difficult. By the year 1937 the NSDAP organisation book, third edition, shows that the tan colored straps piping and numeral coloring indicated the wearers assignment, instead of the Obberbann of the old system. It is also important to note that regulations were not always adhered to, and there was also normally a "grace" period to allow HJ to change over to the newest insignia regulations.
This remained until September 30th, 1938, when HJ straps again underwent significant changes, which will be covered in a later post, along with rank, specialty and DJ shoulder straps.
Period Uniform Regulations for HJ Shoulder Straps
These scans are from Uniforms of the HJ Regulations and Patterns, the officially issued publication from the Reichs Youth Leadership of the NSDAP in 1933.
First photo. 1934 regulation single Schulterklappe from Bann B35 Schweinfurt. At this time the Bann was located within HJ-Obergebiet Süd, HJ-Gebiet 18 Franken. Note the chain style stitching of the numerals used on the early period straps. The green piping and Bann number denotes Oberbann 3 Unterfranken. The roman numerals denote Unterbann II. Second photo. 1933-34 regulation single from Bann B15, Obergebiet Süd, HJ Gebiet 19 Hochland. The roman numeral denote Unterbann IV.
First photo,1934 Regulation single Schulterklappe from Bann 171 Mannheim. At this time the Bann was located within Obergebiet Süd, Gebiet 18 Baden. The green piping and Bann number denotes Oberbann 3 Nordbaden. The Roman numerals denote Unterbann II. Second photo, 1934 pattern single from Bann 57 Wesel-Stadt before being renamed to Wesel but still during the period where this type of strap was worn. Green piped for Unterbann II, Oberbann 3, Obergebiet West, HJ Gebiet 12 Westmark.
1935/37 period HJ schulterklappen pair from Bann 335, Schwienfurt. At this time the Bann was located in Obbergebiet Sud, HJ Gebiet-18 Franken. This Bann was renumbered in the timeframe of 1934/35 from B35 to 335 , (see the B35 strap post). These straps are from the tranisitonal period when the Obberbann system was abolished and the straps showing the assignment were introduced. The red piping and numeral may denote Obberbann 1 or General HJ, without knowing exact date of manufacture specific identification is difficult. This pair appears to have been put together from different sets. Note the holes in the strap on the right where rank pips or button snaps have possibly been removed, and the different coloration and shape from washing and wear. Also note that on the early period straps, 1934-1938, the stitching for the numerals goes all or part way through the backside of the straps.
1935/37 period single HJ schulterklappe from Bann 160, Bonn. At this time the Bann was located in Obbergebiet West, HJ Gebiet Mittlerhein. The blue piping may denote Obberbann IV or a transitional period Flieger HJ, as specific date of manufacture is not known. This one is interesting in that there is a tounge sewn to the back, which passed through a loop on the uniform, to allow for removal during washing. Modifications like this among the HJ were common.
1935/37 period single HJ schulterklappe from Bann 131 Hamm. At this time the Bann was located in Obbergebiet West, HJ-Gebiet Westphalia. Note the RZM tag on the reverse. By regulation the first tags had to be blue in color with TA and, as such, were used officially until spring 1935 when the TA was replaced by the A4 code, due to a re-organization. A tag with the "TA" officially should not have been used if the strap is post 1935, but one with "A4". It is possible the manufacturer still had old tags,but according to orders for the RZM inspections the old one was not allowed to be used in 1936. The "TA" refers to Textilabzeichen. The manufacturer is 260, this should be August Orlob II. from Leinefelde. He first had his manufacturing permission in 1934. It was renewed November 9th, 1935 and had this number until the end of the war. (Thanks to Wilhelm Sarris for the RZM information.) The yellow piping and numeral may denote signals HJ, which as a special force, was introduced August 21, 1936. It is more likely Obberbann II, from the time period when the Unterbann system was in process of being abolished, due to the period of the RZM tag.
Examples of early Landjahr straps. First pattern worn for a very short period in early 1934 in combination with the rare black background Landjahr triangle. Photo from Huesken militaria. Second 1934 pattern Landjahr pair worn in combination with the green background triangle. The stitching on this pattern strap passes through both sides of the strap. This was the first pattern Landjahr strap which was worn in combination with the early black triangle(first part of 1934), which was changed to green according the regulations dated 28 July 1934. Third photo is a single first pattern Landjahr for the rank of HJ Sharfuhrer. This one is well worn and has seen some use. These straps are from Paul Ayerst's collection.
First photo.1936-37 period pair from Bann 451 Zellerfeld-Harzburg, Obergebiet Nord, HJ Gebiet 8 Niedersachsen. This pair is from the period after the Oberbann system was abolished as evidenced by the high Bann number. Possibly early signals HJ as these date to the period when the specialty straps colors were introduced. Note how the numerals are chain stitched through both sides of the straps.Second photo, left. 1934 pattern single from Bann 218, Obergebiet Mitte, HJ Gebiet 17 Thüringen, Unterbann 1. Note the chain stitched numerals. Possibly Signals HJ as the first set of straps. Right. 1934 pattern single from Bann 28, Obergebiet West, HJ Gebiet 12 Moselland, Unterbann III. Note the thin style chain stitching of the numerals. These straps are all from Paul Ayerst's collection.
Very early shoulder straps prior to 1933 were worn by youth elements that sometimes employed a dual colored piping that was possibly an indication of the Landesfarben, (National Colors used by each German state), that went around the sides and to the point of the boards. The exact meaning of the piping is somewhat confusing. Often times the Bann numbers do not match the Landesfarben that the Bann was located in. Another possible explaination is that early HJ reused the colors of the imperial army (Kaiserlischen Armee).
It has been noted that in some cases rosettes on Imperial German spiked helmets matched in color and region to the piping. These sets are from the collection of member Widukind.
Another pre 1933 HJ pair. Note the dual colored piping and simple stitching the preluded chain stitching of numerals. Also note that many pre 1933 HJ straps have the numerals sewn in black despite having differing piping colors.
Extremely rare pair of shoulder straps, of an Oberbannführer in Gebietsstab
(staff of district) around 1935. The background color of this set appears to contradict what is written in the J.R. Angolia's HJ, Vol 1 , page 216 to 217.
The text state that the straps of an Oberbannführer in staff of district are carmine in color, however this set appears to be more of a pink shade.
The silver embroidery is with silver twisted cord piping. Note how the straps are a mirror image of each other, one facing left the other facing right. This set is from Widukind's collection.
Very early pre 1933 pair for a Scharfuhrer from Bann 243 Westerwald, Unterbann V, HJ Gau Koblenz-Trier. There was never a triangle issued for this district. This set is very large compared to other later HJ straps.
1936 pattern for a Rottenfuhrer from Bann 334 Wurzburg-Land/Kitzingen, Obergebiet Sud, HJ Gebiet 39 Mainfranken. The Bann dates to 1936 as that was the introduction year of this Bann. Note the slip on litzen. This set was manufactured prior to the factory applied litzen or it was added as a later promotion.
An example with Unterbann VII from Oberbann 3
Gefolgschaftsführer boards of HJ-Bann B 24 (Fürth / Süd Franken).
I cant find much info on these, and think would be a good thread to ask.
What bann does the red and white piping designate?
Thank you
That's a really nice shoulder strap you got hold of. It's a very early version.
Since no one has commented on it so far, I'll try to give you some information, even though I'm no expert on these early editions.
According to Wim's "Handbook og the Hitler Jugend" it must be from the HJ-Gruppe Ost/Ostmark (Berlin-Spandau - Brandenburg), since after the reorganization in 1933 they use red/white piping.
In the same book it says that Bann 35 on 1.8.1933 is Zauch-Belzig-Brandenburg.
When you put this information together (2 x Brandenburg), you have a suggestion for where your shoulder strap comes from.
I hope you can use this information - if you have Wim's book, you will find the information on pages 634 and 656.
I know in this lovely forum there are members who know a lot about these early versions and hope they see this thread.
Michael :denmark
Yes, every German state had its traditional colours (and almost every federal state still has them today, called Nationalfarben).
The HJ groups included several states, so there were also different colour combinations.
E.g. Ostpreußen/East Prussia had - unsurprisingly - black and white as its colour combination.
Michael has already correctly assigned the red and white - it is still the state of Brandenburg today. The HJ belonged to the SA during this period and adopted the colours of the respective region - and they in turn used the traditional national colours, as already mentioned, and usually the number of the locally stationed regiment in order to symbolise tradition and continuity.
As far as I know, Berlin-Spandau was the headquarters of the HJ group Ost/Ostmark. In those early days, the district of Zauch-Belzig was a decent piece of land from Brandenburg (City) to Potsdam.
I can't contribute more, but I'm sure some others here can.
